Old 02-22-2018, 09:50 PM   #1
impboy
AOS symptoms and repair experience
I wanted to share my experience with others regarding my air/oil separator failure.
On my way home from work, my '01 Box started missing and stuttering in 1st and 2nd gear. Then I came to a stop light and the idle started to go up very quickly to about 2k and then back down. It did that a couple of times. Then it was back to missing badly as I pulled away from the stop. I got on the freeway just trying to get home. Again, more and more missing. At one point, I saw a bunch of smoke coming out the back. I was less than 1/2 mile from home so I went for it.
The next day, I contacted my mechanic and told him what was going on. Right away he said he thought it was the AOS. I had it towed to the shop because I truly thought I may have just wrecked the engine. Just under $400 for parts and labor, the AOS was replaced and the car is running just fine.
As I look back, I wouldn't have tried to get the car home (less than 5 miles). Everything worked out but it could've been an expensive risk.
I've actually replaced the AOS myself before but it was a few years back. I don't recommend it unless you have the right tools and a bunch of hours to kill.
Lastly, when I took the car away from the shop, I tripped a P1128 and a P1130 code. The oil cap wasn't put back on tightly. Problem solved.:dance:
2001 Boxster - savanna on black
1960 MGA
http://i8.photobucket.com/albums/a18...7/mgaside2.jpg
impboy is offline   Reply With Quote
