Old 01-17-2018, 07:50 AM   #1
The Radium King
The Radium King's Avatar
bleed or flush? bleeding just pushes out old fluid near the calipers; flushing changes it all out.
know your torque for the bleed valves - easily stripped.
have a flare wrench to open and bleed.
have a tall socket for torquing after.
start from furthest (rear right) and finish closest (front left).
if just a bleed, you may not need to put any fluid in the bleeder - just use it to pressurize the reservoir. even with a flush, if you keep an eye on the reservoir and don't run it dry - makes clean-up easier.
