Old 11-29-2017, 04:02 PM   #1
Gilles
the problem you may run into by using a used rubber/plastic component is that plastic hardens as it ages and you may end in the same place sooner than later...
IMHO, on these type of components is better to buy a new part, at least is a little over $100.
Wait until you need the plastic tube (that includes) the vapor recirculating valve that connects the throttle body with the carbon canister...
