Thread: Clutch failure
Old 11-20-2017, 10:50 AM   #1
Gilles
Originally Posted by ray_pilot View Post
Need guidance in a clutch issue. Yesterday after driving 50 miles one way with no issue, coming off the interstate I shifted into neutral and the clutch fell to the floor. Coasted off but the clutch would not come back up. It was flat on the floor. After I stopped, I could pull it up by hand but if I tried to shift with it, it simply fell right back to the floor. Checked the brake fluid. Was only a tiny bit low. Added some more fluid and it came back up. Worked normally and managed to drive it home. Obviously need to check the clutch master and slave cylinder. But what else? Could a bit low fluid really have caused the clutch to fail? Advice? Thanks.
Ray, don't know how many miles your car has, but for the symptoms you are describing I would replace the slave cylinder, as is not too expensive but very critical for the proper operation and it's a fairly straight job.
The master is a bit more elaborated due to the location, also check the condition of the rubber hose that connects to the slave.
Good luck!
PS: i don't believe that a slightly lower fluid level would affect the clutch operation, however a good bleeding could help a lot..
Gilles is offline   Reply With Quote
