Old 10-23-2017, 06:53 PM   #1
Ciao
Ciao's Avatar
Originally Posted by Anker View Post
Why won't you push the car back and forth, that's exactly what you need to do! The other alternative is to drive it about once a month when the weather is over 40 degrees (assuming you are on summer tires) and there's no salt on the roads.
Many agree once the oil is changed, driving and parking again for several weeks contaminates internal engine parts, unless you drive regularly once you've started to drive with clean oil. Moving the car back & forth may be a solution, though I was looking for a trouble free solution
5280 Cruising @High Altitude
Seal Gray & K&N Filter
