Old 10-18-2017, 05:26 PM   #4
KRAM36
Need For Speed
KRAM36's Avatar
Did you have to dismantle It or just pull It out apply the glue and tuck it back in the slot?
Mine came loose at the same spot. I used the following glue.
https://www.amazon.com/Q-Bond-QB2-Q-Bond-Repair/dp/B00HX704NG/ref=sr_1_1?s=automotive&ie=UTF8&qid=1508372282&sr=1-1&keywords=Q-Bond+QB2+Repair+Kit
Just pulled the top back in place as good and tight as I could in the center and laid down some of this glue in the center area to tack it in spot. It dries quick and holds very strong. Then I followed along the rest of the loose area applying the glue while stretching the top into place. It only takes this glue about 20 seconds or less of you holding the top in place and it's done. Has not came loose since.
2003 Boxster S
