Old 10-10-2017, 04:22 AM   #2
flouese
flouese's Avatar
If I can figure how to disconnect the lines to them and check their voltage, I will try that first. Again, I still cannot figure how to get in there to disconnect them. Looks like another evening trying to figure this out. Thanks for the assist.
Originally Posted by rczap View Post
Did you see my post on this?
http://986forum.com/forums/performance-technical-chat/63180-cam-position-sensor-replacement.html
I replaced both cam sensors. I did not have all 3 codes like you do but after I replaced the passenger side sensor I got a code for the drivers side sensor. I replaced that and the code would not go away. So I took it to a indy shop and they found the passenger side cam positioning solenoid was bad. They replaced it and I have been code free for over a year.
Edit: I did not have to remove anything except move the AOS out of the way for either sensor.
99 Boxster base
1966 912 3 gauge
flouese is offline   Reply With Quote
