Old 08-24-2017, 03:17 PM   #1
JFP in PA
Originally Posted by Xpit77 View Post
One of the PO must have cut it to remove left intake ? I started to smell fuel so I looked for a leak. The person put a union and two hose clamps to re-join it. It was hidden behind a piece of black flexible wire tubing ? Hence the need to replace. I`ve looked at it numerous times and I thought the flex tubing was OEM ? I read I don`t need OEM part but it didn`t have the dia. I want to get it before I cut the old one out.
You cannot buy just the OEM flex line, it only comes with the rails. These lines are single use barbed fitting lines in a metric size that is hard to come by.
