Old 07-05-2017, 12:12 PM   #1
felipe01
Exclamation Coolant overflow
hello to you all
Ive got a issue.... every time I put the coolant to level ( min or max) then turn the engine on let it heat up... before or at same time the fans goe on... the coolant just appears under the right rearside wheel ......
its from the overflow... but whats causing this problem?
Breather valve?? got it out "looks" ok O- rings look normal to me ( don't see a problem)
water tank CAP ??
worts of all ... water pump in some way...??
Would appreciate some advice
Its a 2.7 2001
Thanks to you all
felipe01 is offline   Reply With Quote
