Old 06-25-2017, 07:49 PM   #11
Fyeganeh
Fyeganeh's Avatar
Originally Posted by njbray View Post
I always say if you are not going to drive the car far enough for it to properly warm up - don't bother taking the P car at all! It's better to let it sit until a longer trip.
If you never go on longer trips (at least 50 miles?) is it worth having that car at all?
Go and have some fun and give the car a good drive - then it makes it worth the oil change!
Well a couple of points.... the money isn't really the concern, it's more a question of is it overkill to change high grade synthetic oil after only 1100 miles of use when the manual says you only need to change once a year or 10,000 miles.
The question moreso was one of burning off water and contaminants - I've heard that a lot on here. The reality is that the oil gets as hot in my 15 minute commutes as it does on my 1 hour trips to D.C. On the one hour trip, it's at that temp for 50 minutes and on the 15 minutes it's at that temp for at least 5 minutes. But then it sits in a garage where it's likely close to that temp for another 10-15 minutes before it cools off. So how long does it need to be at that temp? If you do only a 5 minute commute you never reach the highest temp. Is just reaching the highest temp good enough? If not, how long at the highest temp is required to "clean" the oil? Aside from the contaminants, it doesn't make sense that a high grade synthetic oil should wear out after only 1100 miles.... but that's why I asked the question- to learn from everyone.
As for having fun with the car, I've had plenty of fun with it and enjoyed it a ton since buying it new 17 years ago. I've taken it to the track multiple times and used to drive it 12,000 miles a year, but times change as you get a growing family and move. It now has about 65,800 miles on it and it so happens that I live close to my work so my commute is short. Driving to work with the top down five days a week in the winding backside country roads is plenty of fun whether spring, summer or fall :-) and I don't miss the congested highways. My long distance travel typically involves 4 people now and so the Boxster doesn't cut it most of the time when there are longer commutes :-(
Fyeganeh is offline   Reply With Quote
