Old 04-24-2017, 04:47 PM   #1
dulmer
dulmer's Avatar
Yep. The synch code means that one or both of the door latch mechanisms have faults and are not both locking and/or seeing "door safe" when the door is closed. Do the windows fail to drop when either inside or outside door handle is used?
It could still be an immobilizer or wiring issue, but the door latches are the obvious answer.
I would also remove the aftermarket keyless entry until the problem is solved because it very well could be contributing or causing the problem. If you want to keep using an aftermarket keyless entry, thoroughly test the unit you have or just replace it. The $13 unit I use has excellent range and has worked flawlessly for years, so a decent one is not expensive.
Yeah, neither window drops from inside nor outside door handle. The funny thing is that when I first went to look at the car, the driver window would drop. Once he got the passenger door regulator "fixed", neither of them drop. I'll remove the aftermarket keyless this weekend, and maybe open up the immobilizer to see if there is any sign of obvious damage. Thanks for the help!
dulmer is offline   Reply With Quote
