Old 04-12-2017, 05:22 AM   #11
JFP in PA
Originally Posted by pidj View Post
So why does it matter if there is metal present POST IMS change? When we detect metal, we swap the IMS (to alleviate the metal presence) - would more frequent oil changes and monitoring not clear the shavings? If not, then any metal presence would mean the engine is toast regardless of what was or is done, non?
It also begs the question about the $$ 'solution' option (oil pumped into bearing-less 'bearing')? Nedlands is right: What are you supposed to do? Doing it could be bad, not doing it is bad, metal shavings after doing it is bad .... bad bad bad.
Using an "open"style bearing such as the LN or some other retrofits on an engine with circulating metal debris quite often leads to very quick failure of the new IMS bearing. If the pre retrofit inspection finds metal, we stop the process and will not move forward. If the engine is full of metal, it needs to come out an apart for a full rebuild. Installing a new IMS bearing is throwing money away.
