Old 03-18-2017, 01:53 PM   #17
jsceash
jsceash's Avatar
Looks like a good lift. My concern would be is there enough clearance to drop your motor etc. I've had the Maxjax also since 2010 about a month after purchasing the car. It costs more but over 6.5 years of not taking the car to the Porsche dealer or a independent it has paid for itself several fold. It makes the motor or transmission removal simple. I use a 24. Bike jack and then slowly raise the car off the motor. I believe that would be harder with a jack system that does raise straight up. Those fold down jacks all Raise on an Arc.
Motor and trans out 3 times
Trans alone 3 times
Strut replacement.
Control arms 2 time once standard arms, once GT3 arms and toe-links
Oil and filter about 5 times a year. Every other track weekend at least, and year end.
Exhaust system R&R.
Trailing arms.
Tires before and after every DE and AX.
Brakes before and after every DE since starting to use race pads
Bleeding and flushing brakes. Flushed 2 times a year and bleed before every DE
Cooling system Mods twice.
Power steering Mod.
