Thread: Oil Coolers?
Old 03-17-2017, 01:05 PM   #1
Need_for_speed
Actually, the S cooler fits perfectly, and is one of the best upgrades you can do the money. And oil to water coolers are actually more efficient at heat transfer than oil to air, plus you have no place to put an oil to air cooler. Add a 160F stat with the S cooler and your oil temps will drop 25-30F.
Awesome! Not sure where I read that the S cooler wouldn't fit, but I probably got it wrong anyway. Thanks JFP, that is certainly a really easy solution. I haven't checked Pelican to see if they have any S coolers available. Can I assume that this component is free from wear issues, in which case I can buy a used part (hello Woody)?
Am I on target with my analysis that overheating is the primary issue, or should I still consider a deep sump or accusump?
RK, thanks for the article. That is a very elegant solution.
Need_for_speed is offline   Reply With Quote
