Old 03-17-2017, 04:51 AM   #23
Monkey2
2001 Boxster S key fob problem
Issue: pressing buttons on fob, red light comes on but nothing happens.
Replaced buttons and battery but still the same. Would work if I pressed hard or if I took the circuit board out of the key and press button with thumb with index finger underneath pressing on the battery.
If I hold the edges of the circuit card and press button does not work. Thought it might be battery connections so I removed the battery holder from the circuit card and hard soldered the battery to the circuit card.
Still did not work unless as I pressed button with thumb while pressing underneath against the lower(flatter) of the three chips on the board. Light bulb moment, with a small tipped soldering iron and magnifying glass I reworked the solder joints on the chip now work first time every time back in the key.
Hope this helps.
Monkey2 is offline   Reply With Quote
