Old 02-17-2017, 08:37 AM   #1
rexcramer
1997 Tip, 2018 Macan
rexcramer's Avatar
Yours is under the car. You will need to pull the covers off before you will be able to see it. Be careful jacking the car up and only use good jack stands to hold the car up. If you are going to work on the car yourself, I would suggest that you buy a copy of the Bentley Manual for Boxsters 1997-2004. I have found it very helpful.
