Old 02-08-2017, 10:45 AM   #1
KRAM36
Need For Speed
KRAM36's Avatar
Harbor Freight has a torx socket set with the correct size T55 IIRC
Thanks for that info. I wasn't sure if it was T50 or T55. My Torx bit set went from T40 straight to T60.
Originally Posted by WorkInProgressK View Post
If you don't get noise don't put them. I was thinking the same when I installed my performance HP+ pads. I WAS WRONG. Night and day difference with the damping plates. The noise would be unbearable.Then again I run drilled rotors because its the Carrera discs on the boxster S. You may not need it with slotted and plain discs. Just use a flat screwdriver or butterknife or pry them off and try not to bend them. You can install them later on by removing one pad at a time and sliding them in. It is just easier with the calipers off.
They were not on my brakes. I would have to purchase new ones. I never had brake noise prior to installing the new pads and rotors and don't have any noise currently. My rotors are directional drilled and EBC Red Stuff brake pads.
