Old 01-31-2017, 03:54 PM   #1
steved0x
steved0x's Avatar
Originally Posted by AZ986S View Post
Fronts I slotted and got -2.0 degrees camber.
How much did you have to slot to get to -2 with stock ride height? In my opinion -2.0 is the sweet spot for street tires like the R-S3, it doesn't wear the edges too much (inner or outer) and doesn't roll over on the edge or slide as much as stock camber under hard cornering, and doesn't overheat as much due to less sliding from oversteer. I run -2 in the front using GT3 LCA, slotting would be much more inexpensive way to do the same thing (essentially free...)
If you took any pics during the process you should make a DIY it would be good info to have.
Glad for the info on the Eibach bars as well. I ran just the rear bar for a while, sounds like I probably should have gotten the full set.
