Old 01-18-2017, 03:38 PM   #2
JFP in PA
Thanks JFP .That makes perfect sense.
The warning about the pump is something I did not know.
Just trying to improve the overall cooling issues. I have to remove the existing heat exchanger to replace leaking oil seals ,so while I am in there I thought ...... But now you have simplified the task. Thank you.
The new seals I fitted to the HeatX after the rebuild have failed already ! So I hope the ones from Pelican perform better than those that came in the rebuild kit of seals..
Get the factory seals, they are cheap and we have never had one fail on us.
