Old 01-14-2017, 07:47 PM   #1
dghii
For the parking brake, loosen the adjustment bolt in the interior, under your center console cubby. When the rotor is off, you'll see where the cable terminates on the hub and can disconnect it at that point. You pull the cable out of the hub and you're all set.
