not for the faint hearted the hack to lower your top is by removing the top control unit and either break or tape over pin #18 on your relay....you will need however to raise your emergency handbrake one or two clicks (enough to light up the brake indicator).....beware there is no speed limiter, top should not operated at speeds over 25mph....there is anothe hack to by pass the emergency brake thing, It's just a little more elaborate....The reason I like it is because living in the tropics we get surprised by unexpected showers and many times gets me with my top down....it always helps to be able to cover up when traffic slows down and not pull-over to stop pull the emerg. brake and get soaked.
