Old 11-28-2016, 05:23 PM   #4
Meir
1999 base
Meir's Avatar
Originally Posted by Walshie View Post
Hi Meir. Thank you for taking the time to help. As you say the heater core is in the centre of the car. But I am not sure this is the problem. The car does have AC but it doesn't work( another project) the rain water comes in approximately centre of the passenger side( Rh drive) around the extrusion that I believe houses the AC pipes going to the matrix. I have found this while running a hose into the scuttle panel as just a trickle. The scuttle panel area does not flood. I am hoping that in removing the heater box that I can replace any seals.
I am hoping this makes sense to you.
got it.
in that case, it could be from this seal:
if the seal is fine, pay attention to the lower bolt.
i didn't have any leaking issues, but you can see from the picture that the bolt is a bit rusted at is base, evidence of it being in contact with a lot water.
good luck, and keep us posted.
i'm really curios to see where the lick is coming from once you find it (and i'm sure you will).
