Old 08-05-2016, 03:20 PM   #14
911monty
911monty's Avatar
Originally Posted by imari View Post
I decided to at least give it a shot. I am almost 100% sure that it's the immobiliser. I have a good amount of water soaking the carpet so I pulled the seat out and took the unit out to find that it is wet and parts of the board look corroded. I'm drying it and wiping everything down but I'm not sure about next steps. I'll post after a few test.
Whoa that last image is frightening. You might want to search cause I'm going by my old memory but I think JFPINPA has suggested drying the board, lightly remove corrosion and soak in Rubbing alcohol overnight, he says they have resurrected many this way. But search before you use that bottle of Don Julio, you may need that for later.
There is also an outfit in FL that makes the waterproof immobilizer box that can repair your original board for like $250-300.00 IIRC?
