Old 07-21-2016, 09:03 AM   #4
JFP in PA
Originally Posted by MWS View Post
Quick update, soon as I hit "post", shop called. Apparently they pressure tested system and ran at temp, they say it is the coolant cap (apparently there have been revisions). I don't know if I accept answer, as when I added water, some poured out immediately underneath; granted, I spilled some, but appeared more leaked than was spilt. Also, my trunk carpet was totally dry.
Is it possible to loose that much coolant via cap within 30 min???
Yes, it is. Food for thought department: I would seriously consider replacing the cap and the tank while the car is apart for the IMS. Much like the AOS, changing the tank with the car assembled can be a knuckle skinning couple of hours; with the trans out, like the AOS, the tank connections are out in the open and the tank can be swapped out in a few min. Word of caution: Do not use an aftermarket tank. We have had zero luck with them, and now only install factory units.
