Old 06-25-2016, 01:50 PM   #11
78F350
Motorist & Coffee Drinker
78F350's Avatar
huh? Completely lost now man. Roller bearings have nothing to do with 'thrust', I'll check again but last time I did it wasn't lolll I would have expected the use of the roller bearing to defeat any great centrifugal force/load that the shaft could have made. Interesting....
Thrust? as in gravity pull under accel? momentum (kg.m/s)? data based on what exactly? If you know. Not that I care to know, just curious
I'm no engineer, but in this reference I think that "thrust" is referring to motion perpendicular to the axis of rotation.
I would not expect a lot of force in that direction on the IMS, but a slight oscillation at high RPM over time could wear a roller style much more than a spherical ball. ...?
