Old 06-20-2016, 01:27 AM   #1
JFP in PA
Originally Posted by Bebbetufs View Post
I'm having trouble separating the transmission from the engine. I've removed all bolts I can see and it is clearly loose. Still I'm unable to slide it back to free it. The car is very low at the front so it needs to slide back and up. Pulling as hard as I can moves the entire drivetrain but the transmission is stil stuck on.
Do I need to mess with the clutch fork?
It should just slide right out if everything is disconnected and correctly supported, and all the bolts are out, but it would not be a fun job with the car on an angle as the weight of the gear box and gravity are working against you.
