Old 06-06-2016, 07:59 AM   #1
JFP in PA
Originally Posted by 986Steve View Post
I have a 2001 Boxster 2.7l w/ 75k miles. I forgot to cover it over the weekend and wouldn't it be my luck that an acorn fell off the tree and clogged the drain... I'm sure you all know what happened next.
My question is this. I want to make this a track day car and am not really worried about it getting stolen. I've read incident after incident of people with this same problem. I saw a post a while back (not sure if this forum or another) that there is a way to bypass the system completely (albeit some re-wiring is needed. I would absolutely love any information that someone may have on this.
If that is not possible i'll just replace the ACU (anyone know where to get a new one). I already have a Porsche authorized service station that will program it for me for 200$.
You cannot just by pass the alarm unit with wires, the DME is programmed to wait for a signal from the alarm system before allowing the car to start. That programing is not going to go away..
Before going the replacement route, pull the seat and the alarm module, allow the carpeting to dry completely. Open up the alarm box and flush it with either electronics cleaner or simple isopropyl alcohol, allow to dry. Change the fuse in the alarm unit. Reinstall everything and it will probably work (better than a 50% success rate on this).
