			Use the "Search" on this forum for "Double Din" and you will have complete step by step instructions in Multiple thread with pictures and recommendations.
 Thanks to this forum about the only thing a DIY type can not do without a lift is an engine overhaul.
 A simple floor jack and 2 jack stands  allows you to do everything else.
 Don't be fooled, the 986 is a fairly easy car to work on as many, including myself have found out, so there is definitely an alternative to the dealer and a pile of $$$$
 About that missing sound, try the fuses first and make sure the amp in the Frunk is still functional.
				"It broke because it wants to be Upgraded   "
Short Shifter, Touch Screen Dual Din Radio, 03 4 Bow glass Top  (DD & Auto-X since May 17,2012)
