Old 05-13-2016, 06:52 PM   #21
JFP in PA
Originally Posted by GTsilber View Post
Wow tons of info here, not what I wanted to hear but not much I can do about that. So the consensus is that if any sort of metal fragments are found in the oil, don't drive and find the source of the metal? Is there anything else I can do to try and isolate the source?
Man this sucks, but not as bad as if my engine blew. Can someone recommend an m96 mechanic in South Florida?
Sent from my Nexus 6P using Tapatalk
When you find metal bits, two things are critical: First, is there a lot of it, or just a flake or two? All engine's shed metal in small quantities, but if there is a lot of metal, there is a problem somewhere. Second, what kind of metal is it? Small amounts of non ferrous bits again is not unusual in a nearly all alloy engine, but if the bits are ferrous (can be picked up with a magnet), it is coming from something critical (cams, valve springs, oil pump, cranks shaft, etc.) which should not be ignored, particularly if it is in quantity. Running or driving the car further would not be advisable as the problem is not going to heal, and the circulating debris is eventually get to something really essential, like rod or crank bearing shells, which will put a sudden strain on your wallet.
