Old 05-12-2016, 08:39 PM   #1243
F18febe
Headlights
Originally Posted by c_maldonado2001 View Post
F18febe, does the Pelican package include the clear corner lenses
and how did go on doing the LED DR1 was this through like an LED light strip
that was cut to fit or do they come custom.
carlitos
The project is a headlight retrofit, so I used the housings of my original headlights. What you get from Pelican Parts are new HID GT3 projectors. You need to remove your headlights from your car, if you want to use your current headlights which you may not want to because they still have the amber lenses, and open them up to remove the halogen bulbs. Once the halogen bulbs are out, and you removed the burnt lenses, you insert the projectors and paint the interior parts if you want to, and reassemble. It is a lengthy project, but once complete it makes a big difference and updates the look of the front end.
The Daytime Running Lights that I installed are not custom to the Boxster. They install in the grill on your bumper. Installation was a snap if you are able to splice a couple of wires. Instructions were very clear.
'04 Boxster S - Basalt Black, Fabspeed exhaust and sport headers, UD pulley, Pedro's Bluetooth, 18" Cayman S wheels, Evo cold air intake, IPD plenum, 74mm TB, Ben's SSK with ICT shifter boot, Fabspeed ECU Tune.
F18febe is offline   Reply With Quote
