Old 05-10-2016, 11:33 AM   #1
JFP in PA
Originally Posted by Laminarman View Post
Thank you Dave. I had a PPI done and the dealer who did it said at 49,000 miles and the way it's been maintained it should not be a problem with the IMS. The date of engine build was July 2005 for model year 2006. Is it easy to just look under there and see if it's the replaceable bearing or do you need to take stuff off. Getting the car this weekend.
If the replacement engine was built in 2005, it could go either way. The only way to know which bearing is in this engine is to pull the trans and flywheel and look at the center bolt; if it is a 22 MM, it is the non serviceable IMS bearing which cannot be replaced without pulling the engine apart. Because 2005 was a transitional year, even Porsche could not tell you more without looking.
