Old 04-22-2016, 10:14 AM   #2
boxster
probably the oil fill tube that runs from the trunk to the engine - it has a joiner right at the aos that will drip oil if you are chucking the car around.
I will check about that. I didn't know that "chucking the car around" could cause oil leaks. I still ordered a new j tube,as I said, wasn't expensive so worth replacing anyway.
boxster is offline   Reply With Quote
