Old 04-09-2016, 10:03 AM   #10
JFP in PA
Originally Posted by DWBOX2000 View Post
Next question, I dropped my car off this morning. Mechanic is recommended by LN. Very nice guy. He mentioned something about checking the pads that my friend who was there says keeps tension on the timing chains. "Deviation". Something like that. With my lack of explaining it, if you can tell what I am talking about; is this a common problem? He mentioned the ims and the pads being the big issues with these motors. Otherwise he spoke very highly of the Boxsters. Being on a limited budget, now I am nervous about this issue that I had never heard about 2 hours prior. It's not a matter of trust, he passed my sniff test. I am just curious the likely hood of this bring an issue. Any thoughts from you guys that do this for a living? Thanks.
On five chain engines, there are a set of small wear pads in between the cams which wear and tend to cause the cam deviation values to wander out of spec:
This is a common problem, and should be addressed if your deviation values are outside the +/- 6 degrees spec range.
