Old 04-07-2016, 09:34 AM   #10
JFP in PA
Hmmm. From what I can discern, prices for 986's are nearly identical for cars with or without an IMS fix. Mileage, documented service history, and condition are the key factors that influence price and overwhelm whatever small contribution that an IMS fix might have on pricing.
And with over 200,000 Boxster's built and only 10,000 retrofit kits sold, there is still only about a 5% chance that a car has been updated - 95% still have the original IMS bearing.
The actual number of LN retrofits (all types) is closer to 20,000.
In the same sense that a car with a low mileage clutch and new tires may fetch more than an exactly similar car with a 80K clutch and nearly dead tires, buyers that recognize the cost to do a retrofit also recognize its value in a car already done. That said, there needs to be supporting documentation from the shop that did it, or you need to be able to see the oil line of the IMS Solution with the car on a lift before it hits home.
