Old 04-06-2016, 12:56 PM   #11
particlewave
Originally Posted by B6T View Post
The way I looked at it was this... If I have to replace it every 75k, it's not a permanent solution, so I'm going to install an OEM bearing and at least be able to determine if the bearing is on its way out via debris in the filter, and my physically checking the bearing at an interval in-between.
From what I can tell, you can't detect a failing ceramic bearing in the same way because it is obviously not magnetic, and perhaps much worse for the engine and running surfaces if the balls start to deteriorate to a much finer ceramic particle, if not all out fracture immediately and take out the engine in a few revolutions.
Also worthy of note is that FACT that LN bearings do fail regularly, but every time someone posts online about it, Jake Raby and a few of his minions immediately attack the poster and blame him, the engine or the installer. Sometimes to the point that the poster removes the post completely. Over the years, I've witnessed this behavior on at least half a dozen occasions. Very shady stuff...
I'll never buy an LN bearing.
