Old 03-25-2016, 06:29 PM   #9
dghii
Ok. Just put the top in service position, remove tension cables to allow the rear window to be raised up. You should have good access to dig that rod out.
Get a helper to raise/lower the top a bit to help you get access and alo to connect the rod when you do get it free.
dghii is online now   Reply With Quote
