Old 03-11-2016, 12:55 PM   #1
78F350
Motorist & Coffee Drinker
78F350's Avatar
Any progress?
2005 saw a significant of a redesign of the engine, whereas the 2003 and 2004 are basically the same.
I expect that you already have this information from the 101 Projects book and the Pelican Parts tech article:
You can swap in any replacement engine of the same displacement from 2003-08 without having to remap the DME. (I.E. a 2003 Boxster 2.7L with a blown motor can accept a 2005 2.7L engine with no remapping needed).
Could this vacuum pump note be part of the problem?
Vacuum Pump - Starting in 2005, the Boxster is equipped with a vacuum pump that is powered off of the camshaft. This pump was added in order to provide the engine a more constant source of vacuum, which would be independent of the throttle position and other environmental conditions. When installing one of these vacuum-pump equipped engines into an earlier car, simply hook up the vacuum supply for the brake booster, and the secondary plenum resonance valve to this vacuum source.
Engine Oil Dip Stick - 2005 and later Boxsters have no dipstick. Instead the oil level is monitored electronically. When installing one of the later-style M96 motors into an early car, there is typically a black plastic plug that covers the dipstick hole: install your old dipstick into this location. On the M97 motors, there is no mounting boss for the dipstick, so you will have to rely on the instrument gauge.
