Old 03-09-2016, 08:58 AM   #12
JFP in PA
Originally Posted by tomonomics View Post
I've seen them in transmissions, as you're expecting more particles there, but if you've got that much metal in your engine oil, you've got other problems.
Also, while it seems these are crazy strong magnets, I'd still be concerned that oil flow + a large pothole would release a clump of the sludge all at once, which would be more likely to cause a stroke. As opposed to Coumadin (frequent oil changes).
I recall from my Miata days some Blackstone comparisons in oil samples from magnetized filters, but I can't find it. (no pictures, so it didn't happen!)
All internal combustion engines generate a fine ferrous grit as a normal offshoot of parts wear and tear. A major problem is that most of this material is very fine, so fine that it can pass right through an OEM oil filter, and continue to accumulate over time.
Magnets on the outside of the filter housings see all the oil before it passes into the filter media (oil flow is from the outside to the inside in these filters), trapping this material. And if some compressed grit did pop loose, which I serious doubt happens, its first stop would be in the filter.
Serious racers have used filter magnets for years, both to limit the circulation of the grit, but also as a diagnostic tool for checking on the engine's general health.
