Old 01-16-2016, 09:00 PM   #1
cornontherob
cornontherob's Avatar
1998 Porsche Boxster 55,506 Miles and Non-starting motor
Took this car on a trade, but engine problems prevented it from starting and I overlooked a problem. I can part the car out or I can ship the whole thing. Right now it's just sitting in my garage taking up space. It won't start due to something electronic, like a bad neutral safety switch, immobilizer (no signs of corrosion), or a crank position sensor. Engine makes low compression, and the coolant reservoir is empty, which I didn't notice, so it looks like the cylinder walls cracked. Engine may need replacement. The gears in the convertible top may also be broken, I'm not sure, it just won't move. 55,506 on the odometer, won't go up.
  • Motor doesn't start, could be immobilizer, crank position sensor, or neutral safety switch
  • 55,506 Miles
  • Automatic with tiptronic
  • Comes with two tops, one of which has the back window all torn out
  • Dent in bumper, scratch in bumper, dent in quarter panel, little dings here and there
  • Will need to be towed
  • Local pickup or towing/shipping at buyer's expense
cornontherob is offline   Reply With Quote
