Old 01-07-2016, 11:25 AM   #1
JFP in PA
Have you got the low temp coolant valve installed.
It sends coolant to the radiators at a lower temp so I expect the lower coolant temps would also be noticed on you heater.
Actually, the low temp thermostat does not noticeably reduce the level of heat the car produces. The most common comment we get from customers in the winter is that the car appears to produce heat quicker, which is probably as the result of the coolant going into full circulation sooner.
