Old 01-06-2016, 09:21 AM   #2
grc0456
2003 Base 5-speed
grc0456's Avatar
Originally Posted by tommy583 View Post
I would take the seat out of the car. Then lay it on it's back. At this point I pulled the adjustment lever and pushed the seat front towards the ground. I used the hard ground to basically push the back sides of the rail forward while pulling the lever. Once you get them even, you should be good to go. I hope this helps.
Yes, I agree. I just had my seats out to recondition/re-dye and the same thing happened - it's almost unavoidable. Follow this procedure.
One warning - it is easier to remove the seats with the top down. If you do this, don't use the key after it is down. You'll trigger an airbag warning light and need Durametric or dealer to reset (as I need to do now).
