gauges not working
Thanks so much for your reply. I did as you suggested and pulled the cluster (surprisingly easy) checked the connections, and all were tight. I re-checked all fuses to no avail. Is there
some relay that I am missing? Again only tach, speedo, and lower info lights Mileage ect. are not working at all. The needles on the speedo and tach don't even quiver. Thanks again for your input
