Old 10-09-2015, 09:38 AM   #1
JFP in PA
Originally Posted by Duquette5 View Post
Ok it was easy to remove but how the heck do you test it? Either these are impeller chunks or spark plug tube chunks:
Easy, if the debris is in an oil passage, it is spark plug tube bits or chain tensioner wear pads; if it is in the coolant passages, it is from the water pump.
Pulling and holding a sustained vacuum for 1 hour on both the coolant and oil sides is the best test.
