Old 10-02-2015, 07:11 AM   #1
JFP in PA
Originally Posted by seningen View Post
Put in a LWFW and an aftermarket clutch in my car.
The clutch pedal has the same travel as before. However beyond a point (1" from the floor?), the clutch no longer engages.
I have good engagement to a point, then if the clutch pedal travels beyond that, the clutch doesn't engage.
Is there an easy adjustment to either adjust the pedal travel, or slave cylinder engagement?
thanks,
Mike
Hi Mike.
There is no real adjustment on these hydraulic systems. Is it possible you either have a problematic slave cylinder, or perhaps the clutch pivot is not properly engaged?
