Old 08-24-2015, 09:16 AM   #3
JFP in PA
Thanks JFP. Do you see a good reason going for the $208 Porsche OEM vs. the $48 OEM Supplier pulley? The cheaper one has a 24 month warranty.
btw, have you ever seen an AC compressor going out at nearly the same time as an engine issue?
I would by lying if I did; we buy OEM supplier pulleys for the shop.
If the AC compressor is also out, I would check that for noise as well. Timing is probably just a coincidence.
