Old 08-20-2015, 11:48 AM   #1
JFP in PA
I'm diving into changing the clutch this weekend so what are the special tools I will need other than the triplesquare for removing that one pesky tranny to engine bolt, a flywheel lock tool and IMSB replacement tools?
  1. Go to Lowes and get two overly long bolts of the same size as two of the outside bell housing bolts, but about twice as long. Cut the heads off to make "guides" to assist during reinstallation.
  2. Look up a company called Kingsborne Wire Works; for $10 they will sell you the same clutch disc alignment tool Porsche sells for about $50.
  3. Either locate the proper RMS installation tool (sells for about $600, so try to borrow or rent one), or make your own out of some PVC pipe and other bits.
