Old 08-01-2015, 07:07 AM   #1
jsceash
jsceash's Avatar
Thanks to everyone for the input.
jsceash, what would you say the difference in diameter between the base and S hose is? I would think clamping the bigger hose down would leak, but you are proof to the contrary.
I wonder what the dealer does when someone comes in with one of the old retrofit kits installed that had the y hose sized for the base hard lines?!
There was about 1/8" (3MM) difference.
In answer to your second question if it's not a Porsche part they won't want to touch it (Mine is all Porsche part numbers). With a "Y" metal adaptor your probably on your own they won't have a hose to fit and won't want to be responsible to cut one.
