Old 07-13-2015, 06:02 PM   #13
JFP in PA
Originally Posted by PorscheFan5 View Post
Thanks JFP.
Bummer. Now I need to get a DMF now...
While I am replacing the DMF, and given that I will be mating it with the Warp 9 DC motor and not the engine, should I go for a single mass FW? My clutch remains the same, correct?
Thanks!
If I understand you DC set up, it is a constant torque at any RPM. If that is the case, you can use any flywheel that is properly balanced.
