Old 07-08-2015, 05:33 AM   #3
mariosp
mariosp's Avatar
Send a message via Skype™ to mariosp
Originally Posted by bwillia080261 View Post
Both engines have the IMS issue which is probably the scariest problem. They both have common problems with Air oil separators, MAF sensors etc.
The best advice I could give you was what was given to me by a Porsche dealer. If you get the smaller motor you should get the manual. If you get the bigger motor then you can live with either. This was based on making the most of the limited power of the 2.7. Hope this helps.
I have a 2001 S with a manual and I love it.
thanks for your reply....
could you explain me that part " If you get the smaller motor you should get the manual. If you get the bigger motor then you can live with either. This was based on making the most of the limited power of the 2.7"
I didn't clearly understand the meaning!
Marios
Porsche Boxster '04 weekend car
BMW X5 M sd '07 daily car
mariosp is offline   Reply With Quote
