Thread: Hard starting
Old 06-25-2015, 05:03 PM   #1
JFP in PA
Originally Posted by luckyed7711 View Post
To double check: if the ohmmeter readings confirm the above, then the CPS is not at fault for the issue?
It means that the CPS is functioning correctly under the existing conditions. Problem with a CPS is that you need to check these tests when the car does not want to start, like after a heat soak. If the tests check out then, it is probably not the CPS.
